RCU Forums - View Single Post - MVVS 58 pro won't run !!!
Old 07-27-2006 | 08:00 AM
glofuel
Default RE: MVVS 58 pro won't run !!!
mike: it needs to come of so the second magnet can be repositioned to segments away from the first to give the 120 degree timing instead of 180 degree which is cause of this problem.
the drive washer will need heating to soften the glue which holds the magnet and then a new hole drilled in the correct place
Ian
