RE: MVVS 58 pro won't run !!!
Ian
Giving that some thought, would the ignition know what magnet to fire on if they were both the same pole? If they were the same you could get 240deg timming, so it may be that the ingnition module requires a north south signal to operate in the correct sequence/timming and to differentiate direction and revs, I understand that this new module will stop the motor if it starts up backwards, the only way it could know is if it gets the signal in reverse. Prepared to be shot down in flames I am typing this as it occures to me.
Mike
