RE: MVVS 58 pro won't run !!!
Ian
The Yak with the 45 in should come out to just over 15lb, Angus Balfor is using the 58Pro in one and his comes in at 16lb 7oz and said it is a demon, mind you I am not in the same class as a member of the British F3A team. I have had the 45 on back order for over a month now just as well I went fishing to fill in the time.
Her in doors who must be obeyed has indicated its time to put my toys away, signing off will check again tomorrow morning speak to you then.
Mike
