different set-ups
if you want to run pull pull on the rear surfaces take a look at the dp bipe as thats the way dp shows it in my manual. i also set mine up with pull pull on those 2 surfaces The DAve patrick Bipe)
i have the creek extra that i will run 2 elevators servos and run the rudder on a pull pull with the fuel tank o the cg with a perry pump vp-30.
The hanger 9 caps have the 3 servos set up under the wing if you need to look at one of those set up that was built according to the manual if you have access to one of those babies.
