RCU Forums - View Single Post - Tug visor
Thread: Tug visor
Old 07-29-2006 | 11:13 AM
Umi_Ryuzuki's Avatar
Umi_Ryuzuki
Default RE: Tug visor
Is this a conical section, or an annoying elipse?
This is some cardboard mockups I created before cutting the deck rails for the Fire Boat.
I basically cut the rough shape, and then add 1/4"-1/8"- or 1/16th of an inch to top or bottoms till I get what I want. Usually takes two or three tries.
If it is a simple conical section, and you know the small and large diameter and the hieght of the cone, then you can use the "Shroud Calc"
http://www.realmcommunications.com/r...shroudcalc.htm
[8D]
