RCU Forums - View Single Post - How to adjust right thrust?
Old 07-29-2006 | 12:46 PM
LT-40's Avatar
LT-40
Default How to adjust right thrust?
I just recently read the new "From the ground Up" article in the latest MA, and had a few questions about the right thrust section. It tells you how much right thrust you need, and how to figure the angles, but how do you adjust the right thrust?, do you mount the engine off center of the mounts? Do you add washers behind the left mount? Whats the best way to do it?
LT-40
