Okay Guys, I found the problem, but I'm not out of the woods yet..............
I still need your help in making a decission.
Here are my findings;
All servos work perfect with the new Tx & Rx, under one condition, So long as I don't hook up the gyro the Airtronics VG400 radio works perfect with not even one glitch, But as soon as I install the Gyro between the Rudder servo and the Rx rudder channel, the whole radio goes crazy!!! All the servos twitch and my ESC runs the motor on and off erratically.
Here are my 3 questions,
1) Can it still be a bad RUDDER servo, although the RUDDER servo works perfectly normal when plugged into the rudder channel alone ???
2) Is my brand new JR G410T Basic Tail Lock / Rate Gyro Defective
3) Or is it possible that the gyro is set to sensitive and causing havoc on the rest of the system?
Can I adust something to clear the glitches, or just dump the Gyro, it's only 2 months old, brand new out of the box from helihobby.com
My other corona has the same gyro and it works perfect, but Im not taking that one apart to experement.
Any opinions are welcomed.............
