RCU Forums - View Single Post - Extra260 Ign Switch
Old 07-29-2006 | 10:25 PM
japan3d's Avatar
japan3d
Default Extra260 Ign Switch
Just about finished with the Extra 260, and ran across a small problem. I installed the MPI switch in the right hand location already cut out for you at the factory. Now how do I run the wires to the battery and ignition kill switch? Drill 1/2 holes in the engine box plywood that runs back to the wing tube? Or use extensions and run it out the holes already cut in the plywood?
