RE: Setting up an OS 1.60, cline, bisson pitts, 18x6w
Ok, here is where I'm at:
I played with the idle a little more and got a good consistant 1900rpm. I started leaning it out until it wouldn't run anymore which was around 1.5 turns out on the mixture. At that setting transistion was ok, it was still slow and rich moving though the midrange but it wasn't bogging down like before. When it got to the top end I had to richen it up 300 rpm because it started crackeling from deto. I switched to the F plug looking for retarted timing, but that wasn't enough, so I definatly need the shim so I place a tower order for the shim and a few more F plugs.
I think I'll order a few skorepa props on monday, hopefully I can those in hand before this weekend.
schu
