RCU Forums - View Single Post - Best 2 Stroke Oil
Old 07-30-2006 | 11:15 AM
bigger the better
Default RE: Best 2 Stroke Oil
ORIGINAL: ScooterTrash
[8D]Hi bigger the better, From what can understand The oil U R using recomend's 100:1 but U R running a mix od between 40:1 to 32:1! So with the oil I am using it recomend's 50:1 so I should run a mix of 32:1 to25:1. I talked to some of the mechanics at the M/C shop and they said that a mixture with to much Oil will cause the engine to run hotter. Now I am more [sm=confused.gif] Than before!
Ya, I just went off the recommendation chart figured since scooters use somewhat of the same engines - The back of the bottle does indicate in some applications you will need to use richer mix ratios. I don't know, I bet if you where to use any high grade oil it would work.
