RCU Forums - View Single Post - PST contact?
Thread: PST contact?
Old 07-30-2006 | 02:02 PM
speedbrake's Avatar
speedbrake
Default RE: PST contact?
Kelly,
I'm installing a 600R in a R54. This is my first turbine. The manual isn't clear about the fuel system. The instructions say to connect the main tank to the header tank, then the header tank to the shutoff valve, then to the fuel pump, then to a fuel filter, and finally to the turbine. However, the diagram provided shows a different arrangement. What is the correct way to set up the fuel system?
The fuel pump I have doesn't have the mark mentioned in the manual describing the "in" nipple. It has instead an arrow going across the two nipples. I assume the arrow indicates the direction of fuel through the pump; thus the point of the arrow is the exit nipple - fuel to the turbine (?).
Please advise,
Keith Lindsay
