RCU Forums - View Single Post - Welcome to Club SAITO !
Thread
07-30-2006, 02:42 PM
3979
Hobbsy
My Feedback: (
102
RE: Welcome to Club SAITO !
I just made this velocity stack for my Saito 1.25. I used a piece of 3/8 ID KS tubing. I slit a piece length wise and kept pushing it together with my miniature vise and re-slitting it with my band saw until it would tightly slip into a choke bracket left over from a choke removal. I had drilled the choke bracket out slightly so the final ID of the stack would be .5mm larger than the carb venturi. I closed the seam and soldered the stack to the bracket using Silver Solder, the stack extends 1/16th inch inside the choke bracket and rests up against one of the white rings from a previous choke removal. My neighbors and a couple of friends are out enjoying their pool so I'll run the engine tomorrow. The length is 1.125 inches at the halfway point of the baloney cut.
Reply
Like
Hobbsy
View Public Profile
Send a private message to Hobbsy
Find More Posts by Hobbsy
View iTrader Profile
