RE: volcano pull start
Can you pull the pullstarter? and by plug you mean Glow plug right? Try taking like a flathead screwdriver and turn the fly wheel untill it starts moving easily. It it is hard to move at first its just got pressure build up. By doing this your pull starter will be able to be pulled. Take out the glow plug (which you have already done)(I think) and pull it lightly several times. Put the plug back on and try starting her up.
You only need to do this if the pull starter cannot be pulled.
