RE: Showtime
I did get my Showtime in the air to day, 6 flights.I have a problem that the plane will roll(not mutch,but I`m use to pattern plane) in both directions in straight flights,trying to trim it but its like this plane is flying on the edge and will roll.I have HS5945mg all around and they have barely any play (less than 1/10 inc or 2mm) on the aileron surface.Is this the cause or is it still a warp in the wing?It did have a 0,5 degree warp in one wing half I fixed when I put it together.Cg as recomended but fuel tank up front,emtyweight 4055gram (8,9Lbs) w/SFG.
Or is this plane only for very experienced pilots?I didnt like that I have to watch it carfully all the time to fly straight and level.
I did check the plane now and had a 0,3 degree warp in one wing half,and 0,5 degree downtrust on the engine.
Is this the reason to the problem?
