RE: Shrike flight report
Reza:
Sorry, I neglected to post the part number for the reverse cam that fits the FA-91. It is SAI182TD34 from Horizon, I would suppose the same part number would be used by the UAE supplier, but I don’t know. With it installed and timed all the other adjustments are the same, the engine just runs backwards. No other modification required.
Using the FA-120 all you have to do is switch the exhaust and intake pipes side to side, drill two holes in the carb mounting flange to get it sitting straight again. No parts needed at all. Just a couple minutes and two holes.
Bill.
