Very nice Smitty, if you think you had problems with your Roo before, wait 'till you see my pictures ( to be posted Monday ) in the last 3 weekends I stuffed my Roo because a really bad nose steering servo ( change now for a stronger servo ) could not get a flight in at all, it is good now I took my bird to the field with high hopes and it paid off, on the first TO run I had to abort because it just veered to the left ( thanks G my brakes worked this time, no more BVM brakes stuff in my airplanes
) on the second attempt it departed the ground just fine, on the second flight no problems on the TO run and I used my smoke system ( Tam's ) for the first time, all I can say is !!!!WoW!!!!! smoke ..............mmmmmmmmmmmmm and my landing was smooth and the braking, tremendous and smooth....haaaaaa what a relief, too much building not enough flying.
