RE: NASTY STUFF !!!!!! HELP PLEASE
There is a paper gasket in the back plate and a ruber "O-ring" on the carb that could suffer and cause problems if you don't remove them. These motors are designed to be a sealed system with air going ito the carbs ventry and out the exhaust and are sensitive to air leaks causing poor performance.
