RE: dumb prop question
tekajo, I think what your asking is how to mount the prop on a threaded shaft, so we'll go with that, first you put 1 nut on the shaft and run it down till it bottoms out on the end of the threads then snug it, then slide the prop on, from what you described the recessed part of the prop would go to the plane so it sits over the nut you just put on, most props have the size stamped near the hub, you want that facing out, then put a small washer and the second nut on the shaft and tighten it down, there you have it, ready to fly.
aeromite is right, fly a plane is nothing like running a car or boat so go easy on your maiden flight, give it full throttle and a good strong throw straight and level and let it climb up to about 80 to 100 ft before you start turning and make your turns nice a gentle untill you get a feel for it, remember we all crash so don't let it get you down
Good luck
