RE: Powerline Hobbies EDGE 540
If I understand you correrctly, I should add some CF rods to the base of the vertical stab so that it goes down into the fuse through the horizontal stab. If this is correct then I will make sure to add them. Have you had any issues with the bottom of the plane? I noticed that there isn't my in the way of structure, just some stringers and covering. Will this be strong enough or will I need to strengthen it up a little?
Mark
