RCU Forums - View Single Post - Converting an Eagle II to a tail dragger
Old 07-31-2006 | 06:02 PM
B.L.E.'s Avatar
B.L.E.
Default RE: Converting an Eagle II to a tail dragger
Yes, the main gear will have to be moved forward, just enough in front of the plane's CG so that it does not nose over but not so far in front of the CG that ground loops are a problem. At or slightly behind the wing's leading edge is a good starting point.
