RE: Scratch Built Ignition???
Great,,,,,,,Keep use informed.I also believe that the add-on syncro spark by CH will work with this unit.It connects between the pick-up and the hall sensor,Set the timing to around TDC then the SP will automatically advance it during running.[X(]
