RCU Forums - View Single Post - Roo engine thrust
Old 01-03-2003 | 04:02 PM
Ragz's Avatar
Ragz
Default Roo engine thrust
Ok..now my roo gears are sorted out...what abt the engine thrust angle? A friend of mine has put some shims at the BACK of his p120, effectively pointing the engine downwards (tail cone UP, so effectively giving the plane a down thrust). He says this setup makes the plane fly well. He hold full up elevator from the beginning and the roo rotates comfortably.
I remember that there was a discussion on RCU some time ago...where someone suggested to shim the engine from the FRONT...so as to point it slightly upwards (giving it an upthrust). The argument there, I believe was, to compesate for the higher engine thrust line vis a vis the roo's itself.
Are there different setups for different flight characteristics? Advanced vs. novice? I am confused.
Thanks in advance.
Anurag
PS: Enigne is a P120
