ORIGINAL: akschu
Ok, here is where I'm at:
I then tried putting the cline behind the high speed needle which makes the carb pull it's fuel though the needle and the engine ran good, but I couldn't make it rich enough to 4 stroke so that isn't going to work.
schu
Hold your horses here old been.
Lets just confirm the order here, it should be for your engine set-up:
Tank, Cline, HSN then Carb.
You're saying you've had it set-up as:
Tank, HSN, Cline then Crab?
Never seen it done that way, I'm sure it's wrong and it's the first set.up you want.
