ORIGINAL: Supraman93
I would like to know what is the best aftermarket steering servo you can put in the Vulcan being that the stock one is weak.
i JUST PUT in a Hitec HS-56 HB , A tight fit but it works great, requires some linkage adjusting. steering is now tight and fast... also added a nut on each end on the ball ends (too much slop) Size 2mm
