RCU Forums - View Single Post - Why is the fuel not being sucked into my engine?
Old 08-01-2006 | 10:14 AM
Antique's Avatar
Antique
Default RE: Why is the fuel not being sucked into my engine?
Wrong, the reeds are under the carb insulator block inside the engine...The ones you are looking at inside the carb are pump in the carb...These very rarely go bad...Be sure the gasket is on TOP of these when you put the cover back on....
