RE: Contra-piston/head button clearance
Maybe 5 thou to 10 thou. It is not that critical. You want the hole in the head button to compress the O-ring a bit. Then cut the groove for the O-ring in the contrapiston so that you have to force the O-ring into the head button hole when it is on the contrapiston. This is based on experience making a new contrapiston for an RJL 40-size head.
