RE: saito .82 losing power/ surging
Best bet: You have a restriction somewhere. if you have replaced your tank system try removing the HS needle and pump some fuel BACKWARD from the needle opening up through the fuel inlet. Watch your eyes! I have seen this work several times.
Good luck.
