RCU Forums - View Single Post - 8UAF flap programming?
Old 08-01-2006 | 02:50 PM
Krysta
Default RE: 8UAF flap programming?
HI wsmalley,
This should be easy to do with 2 Pmixes, the first one you will want to do is Offset as Master, channel 6 as slave, set this to the center position of your 3 position switch and make the rate 10%. Next do a 2nd Pmix again with Offset as Master, channel 6 as slave, set this to the down position of the same switch, and make the rate 40%.
At top position on your 3 position switch, you will have just normal flaps on your channel 6 knob, but with the switch in the center position, the flaps will drop 10% and in the down position, they will both drop 45%.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta Hunt
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
ORIGINAL: wsmalley
How do you program plain flaps? I want to use the switch 'C' for 2 position flaps-like up, 10 deg., 45 deg. I have one servo each side connected with a 'Y', and am plugged into ch 6. I can only get one movement. and it reverses between middle position and up and down. I did Pmix 1 and basically, at this point, I'm lost!
