RCU Forums - View Single Post - Aileron offset problem?
Old 08-01-2006 | 08:47 PM
Bass1's Avatar
Bass1
Default RE: Aileron offset problem?
Just wondering.. if the top of the aileron is high (slightly thicker) than the wing, the bottom of the aileron most likely will be (slightly thinner) than the wing. This is assuming the aileron was built to plan and is attached above the recommended centerline. If this is indeed the case, I believe you loose your "flutter reducing" benefit. Correct me if I'm wrong though
