RCU Forums - View Single Post - Vspec tuning
Thread: Vspec tuning
Old 08-02-2006 | 09:14 AM
the_yeti
Default Vspec tuning
I have a couple of questions as I have never run a turbo head before.
1)WHen I prime the motor and then attach the glow plug sometimes the motor will completely start up on its own or at least fire up for a revolution. Is this normal?
2) Do you always need to have either the blue or the red insert in at all times when running?
3) The low speed needle that the manual says should be about one turn in from flush seems way rich, I saw a review in xrc and the vspec low needle was set at 1 3/4 turns out from the bottom. What is the normal end running range for the low speed needle?
Thank you in advance
