RCU Forums - View Single Post - Small Spitfire Engines
Old 08-02-2006 | 09:16 AM
  #38
gcb
Default RE: Small Spitfire Engines
ORIGINAL: mro
I have a Baby Spitfire radial mount with no way to mount a fuel tank to the back side.
Any idea what year it is? It has a metal(AL) prop.
I believe the Baby Spitfire is of .045 displacement. They also made a Spitzy .045 with tank included (see pic...reverse pitch prop for pic only). There was also an .049 (several actually..second pic) and the "Royal Spitfire" .065 (3rd pic).
The Baby Spitfire was made to use an external tank (not connected to the engine). It would be an excellent engine for one of the many Scientific "Hollow Logs". You mount the tank in the fuselage and run tubing up to the engine.
The engine was made about 1950, give or take a few years.
I would not use the metal prop. I would try a 6x3 wooden prop...because the crankshaft is small and you wouldn't want to bend it. Use 15%-25% nitro fuel with 22%-25% castor oil lube. If it is new, break it in properly. Remember, this is OLD technology.
George
ID:	500587   Click image for larger version
ID:	500588   Click image for larger version
