RCU Forums - View Single Post - Simjet 1200
Thread: Simjet 1200
Old 08-02-2006 | 11:06 AM
digitech
My Feedback: (10)
Default RE: Simjet 1200
ORIGINAL: turnnburn
Our lipo battery is 2250 mah, 11.1 volts, 12c continuos and 20c bursts. Does this sound like enough or more than enough for this engine which requires a 9.6volt nicad ?
the engine needs to spool faster then 32000 rpms on the starter to get a cool start without the flames and puffs.
anything below it will run hot and become unstable and its very bad for the bearings and then some.
now with the tarabat lipo,s (come standard)7,4 they loose peak power voltage and therefore it is needed to use a 11,1 volts battery.
why dont you guys ask this in the engines section?
