RE: Official HPI MT2 Thread
hey 46u
i did try and fix the pull starter.
i had it wound up. put back on the motor.
it worked for 2 pulls and same thing happened.
i thought. ok i don`t have it wound tight enough.
tried to fix it again. the end of the spring was
pretty bent up by than. it worked for 3 more pulls.
after that i threw in the towel.
i should be able to finish the break in this weekend.
i got some linkage issues to play with.
you know? when i hit the brake the engine dies.
i`ll play around with the linkage and the trims
on my radio. and go from there.
