RCU Forums - View Single Post - DP Extra 330 ARC / BME 50 Progress
Old 03-14-2002 | 04:26 PM
  #96
didiwatt
My Feedback: (38)
Default DP Extra 330 ARC / BME 50 Progress
Bill Pryor:
Got my 3" Tru-Turn spinner and adaptor kit for the Taurus. Forgot to order with the Menz cut so will have to do considerable cutting to fit my 20X10 APC prop. The adaptor kit comes with a longer prop bolt. It is so long where the bolt is not threaded, it takes 2 extra washers plus Taurus stock spacer to even get close to tightening the prop. Was yours that way? What did you do? There was also an aluminum spacer with the kit that is the same size as the bolt but to small for the shaft (back plate is correct size for the shaft) Just curious why it was included. With the Taurus stock engine mount, the closest I could get the spinner back plate to the cowl is 3/8" of an inch which is very disappointing. To much space so doesn't look to good ,thinking about not even running a spinner due to the excess spacing. Major work to change spacing. As it is, I only have 3/8" overlap of the cowl . A picture of you manual choke set-up with be helpful if you would be so kind.
Paul
