RCU Forums - View Single Post - Newly redesigned WH Extra 300S build thread
Old 08-03-2006 | 12:16 PM
  #109
The bird man's Avatar
The bird man
Default RE: Newly redesigned WH Extra build thread
What length servo arm are you guys using for the pull-pull rudder? Are you crossing the cables, if so should I use an offset arm? Has there been any issue with the cables rubbing any formers as was the case on some of the old 28% planes?
