Spent a few minutes down in the garage this morning...
I took some pictures but they were washed out by the flash so I'll redo them tonight.
I separate the wing from the center section and there is no way that joint would have held. It came apart way too easy. It was like the only thing holding it together was the dihedral brace so once I had the saw through that it came apart nearly clean. So now I just have to sand a little to get to some wood on the end of each section, make the new braces and drill the holes for them. It came apart without damaging the exterior at all too so I'm pretty pleased. Once I get it back together I don't think anyone will be able to tell there ever was a problem.
