RCU Forums - View Single Post - DA50 ignition sensor position?
Old 08-03-2006 | 04:48 PM
Tired Old Man
Default RE: DA50 ignition sensor position?
If that's the way it arrived from the manufacturer, it's probably correct. There is no reason to change the manufacturers position unless the timing is wrong. Sensor position is determines the timing. All engines are not the same. See where I'm going? If it runs right, don't change it.
