RE: ST G90 Question?
The screws I was referring to were the two that retain the high speed needle valve assembly in the carb. I will take Dave's advice and remove the carb and check the spraybar before I locktite the screws in.
So I should not worry about the muffler end piece? Is this normal for these mufflers? Toss it and get a pitts? What do you guys think?
Jim
