RCU Forums - View Single Post - CHT
Thread: CHT
Old 08-04-2006 | 04:30 PM
macanaw
My Feedback: (30)
Default RE: CHT
Here is the method I employ.
I picked up a temp gun that has a "MAX TEMP" option. I press this button and pass the gun back and forth over every area of the engine I can hit with it. The gun will then display the highest temp it found.
I do this immediatly after shutting off the engine and then a couple more times after that to see how saturated the engine temp was.
I run a ZDZ 160 Champion and my temps are typically between 180-190 F immediatly after landing. Occasionally on days over 100 degrees I have hit 220 -250 F.
I also check a friends engine. He runs a DA 150 and his temps are right around 120 - 130F immediatly after shutdown, but increases to 140 - 150F in the minutes following shutdown.
I go to great lengths to keep my engine cool since it only take once to heat damage it
Macanaw
David Fox
