RCU Forums - View Single Post - Adding weight to planes
Old 08-04-2006 | 09:38 PM
daveopam's Avatar
daveopam
My Feedback: (9)
Default RE: Adding weight to planes
Weight hurts everything. You mentioned thrust. Thrust is turned into forward movement which is acceleration. This is affected by weight. Also affected are take off and landing speed,cornering and overall manuverability. If you have to add weight then you have to. But it should be the last resort. I would try and slide the engine forward or back before I would add lead.
David
AzChopp3r (12-08-2024)
