RCU Forums - View Single Post - Servo melting problem...
Old 08-05-2006 | 10:09 PM
afterburner's Avatar
afterburner
My Feedback: (18)
Default RE: Servo melting problem...
I would have tried swapping out the RX after the second servo fried. I assume you've already determined the servos not binding on the valve? You must be pulling a lot of current to melt the case. Sounds like an RX problem to me. Do you have a whattmeter or similar to check the current being pulled by the system? Good luck.
Marty
