RCU Forums - View Single Post - Phoenix Strega 40
Old 08-05-2006 | 10:46 PM
p40hawker
Default Phoenix Strega 40
I have a new Phoenix Streaga with a Thunder Tiger 46 Pro. The motor out of the box would not idle. So I adjusted the low end. This fixed it temporarly. But when I got to the field it would die in flight. One of the pro's at the field adjusted the low end a little more and turned the idle screw to run some what rich. This keeps it from shuting down in flight, but it still does not run exactly correct. And if I do a loop or roll the engine trys to shut down. Not sure if it is the engine or the tank or a combination.
Any of you guys got a thought on this ?
