RE: Servo melting problem...
If you've replaced with a new servo 4 times already, it Sounds like there is a short in the receiver on channel 5. Maybe a weak solder joint failed due to heavy voltage (6V packs?) If not, your servo motors are burning up for a reason previously mentioned.
