RCU Forums - View Single Post - firebird commander 2 trouble for noob
Old 08-07-2006 | 08:59 AM
aeajr's Avatar
aeajr
Default RE: firebird commander 2 trouble for noob
[quote]ORIGINAL: writetoaaron
I tried the launching straight not up or down. Also tried the off the ground takeoff too. No dice. Frustrations abound. I appreciate your all's input tho to help a noob. I'm sure you get so many newbie posts asking the same sorts of things. Are there anymore suggestions? If not, what beginner plane would you suggest that is better? Thanks again
writetoaaron
This was written for Aerobird 3 channel flyers,b ut it may provide some helpful tips for you. I don't know hte condition of your plane, what kinds of crashes you have had or if you have damaged the plane. There is good info on your manual on how to adjust and tune the plane. I presume you have been using that.
Take a look here. Remember, the Aerobird Challenger has a V tail, like yours, but it has elevator funciton which the Commander does not have.
I have an Aerobird and an Aerobird Challenger. Combined I have over 600
flights on them. I have taught several people to fly their Aerobirds. Here
is the procedure I tell people to follow to get the plane to fly properly. I
can't be sure how much damage you have done to the plane due to crashes, so
let me just offer this as a starter.
Unless you have removed the white foam that sits between the battery and the
electronics, ignore CG for the moment. Do all of your flight testing with
the
6 cell battery. The 7 cell makes it nose heavy and will change the way it
flies. When we are trying to fix it, I would use the 6 cell only.
1) With your transmitter on and all trims centered, and your battery
connected
in the plane, but with the motor off, look at the control surfaces on the
tail
from the back. Are the movable parts exactly even with the fixed parts? If
not then you are going into a turn the moment you launch assuming the motor
is
straight and the tail is straight. More on that later. Normally, these
surfaces have to be
perfectly aligned.
2) The boom between the pod an the tail - is it solidly anchored or can you
move it around inside the plane. If it moves, it has broken loose. This must
be
fixed. It will either sag causing the nose to go down or it is twisted
causing
the plane to turn right or left.
3) Check the tail, especially by the rigid plastic near the boom. Are there
any creases? I had a problem with my Aerobird that caused it to turn to the
right so badly that it crashed because it would go into a spiral. I tried
everything. Turned out there was a crease in the tail that caused the tail
to
flex under pressure. On launch, this could take you into the ground.
4) It is possible for the tail to shift from a severe nose crash. There are
trim instructions in the owner's manual. AFTER you have checked the other
items and
fixed or found them to be OK, try trimming the tail for more up or down
force.
Other points to be aware of:
When the motor is running, more air moves across the tail so that you get a
faster response for turns. The slower the motor is running, the slower the
plane will respond. When gliding, response can be very soft.
Make sure you are launching into the wind - directly into the wind, or the
plane will be turned by the wind when you launch. Same for landing.
Let me know how it goes.
If this doesn't help, I invite you to post photos.
These are what I would
want to see: All shots are with battery in and transmitter on, motor off.
All trims to center and not touching the stick unless I tell you to. All
tests are in Sport mode.
view from nose to tail - level with the top of the plane - to check
alignments
view from tail to nose - same reason
Remove the wing, lay the plane on a table on its side with the tail hanging
off the end. Place a ruler or a suitable straight edge under the body
extending to the tail. I want to see if the boom
is straight
surface alignment - battery connected, transmitter on - make sure your trims
are centered
For the shots from tail, I want you to center the motor in the frame so that
you are shooting STRAIGHT down the shaft.
view from the tail at tail height - full left command
view from the tail at tail height - full right
same - full up
same - full down
sticks centered and hands off shot.
Finally view from under the tail.
