RCU Forums - View Single Post - Servo melting problem...
Old 08-07-2006 | 09:05 AM
Vincent's Avatar
Vincent
My Feedback: (61)
Default RE: Servo melting problem...
Woketman wrote:<<All that would do is melt wires, NOT the servo case or motor>>.
My company services electronic dispensing and pos computer systems, i can assure you that ANYTHING can happen when you get a spike, surge, short etc...JH, you probably should swap out the ecu and try to find out what is NOT causing the problem which will lead you to what IS the problem.
V..
