RE: Cox Hyperviper
Luke,
Are you using all-castor lube in that engine? Varnishing used to be quite a problem with Cox engines that were run hot. You might try fuel with 25%-50% of the lube synthetic, the rest castor. Maybe it just needs more break-in time.
George
