RCU Forums - View Single Post - first conversion
Old 08-07-2006 | 05:00 PM
davewallace
My Feedback: (29)
Default RE: first conversion
Andrew,
It is most likely a 31cc Ryobi. They come in a short and long shaft versions. You need to know this to order a hub. Most of the newer ones have the flywheel housing cast into the crankcase. You have to cut it away with a hacksaw etc. If you retain the mag ignition, you will have to live with the more difficult starting. Its not so bad.
Dave
