Is Norvel .074 OK to Buy (rod?)
ya , I hear ya spyder and you could have a point, cheap fuel could also be the culprit re insufficient lub----------I try to use non synthetic oil but dont always stick to it))))))) after yrs messin with these things castor seems to be the best protection in all aspects,on the down side castor mix can cause some bad things, but thats solved with engine maintanence. true ,the bottom end of the rod does "slop out on the crankpin and needs to be furture investigated>>>>>>"too many projects not enough time!!!!!
