RCU Forums - View Single Post - Another snap question...
Old 08-07-2006 | 10:59 PM
rcblimppro's Avatar
rcblimppro
Default RE: Another snap question...
ORIGINAL: MikeEast
ORIGINAL: 3D Joy
As a contestant, I often end up judging lower classes. Last week I gave some zeroes to an advanced guy that snapped with the rudder in the wrong direction and agreed with the other judge that it was not a snap --> no autorotation... everything else was there but no autorotation. In fact the plane rolled at a slower pace than if no rudder was applied at all.
I was discussing of this with a full scale flyer that used to fly IAC competition and he told me I should not have zeroed those snaps. He said that we should look for some sort of cone shaped movement of the tail and that it should have been the case even if the rudder was not properly used.
Is he right ?
What do you mean by "snapped with the rudder in the wrong direction" and how does that relate to whther or not the plane autorotates? Please explain. I am new to IMAC (but not new to sequence flying) and really want to understand what you are talking about so that I can apply it to how I execute a snap. I know that there are positive and negative snaps, and can execute both, but what difference does it make it the plane snaps positive or negative with left rudder or right rudder?
Mike, when opposite rudder is applied the manuver is no longer a snap roll. The criteria for a snap is that the wing has to stall or in the case of our models must "appear" to stall (but that is another whole topic there). When opposite rudder is used the airplane flys through the roll and thus cannot be called a snap roll. The wrong manuver was flown so the figure gets a zero.
Shawn
