RCU Forums - View Single Post - K&B .61 engine?
Old 08-08-2006 | 12:17 AM
  #68
rcuser002
Banned
My Feedback: (12)
Default RE: K&B .61 engine?
TimC,
I thought those numbers were a little "off" seeing as how I was getting readings in the low eleven hundreds with the APC 12x6 on the 1st tank, 90 degree day, running 10% castor/synth before I richened it up and lowered the rpms to high 9's.
K&B 61 owners,
I'm still having trouble getting a low idle - the low end screw is 'out' past the 'level with the barrel" factory setting.
I heard it takes 2 gallons before you can really get the lowest idle and full throttle with no transitionproblems.
I'm excited about the potential that my flying buddies tell me to expect once the engine is broken in.
ACCORDING TO THE DIRECTIONS FROM THE BOX, As I lean out the high end, I should be richening (turning counterclock) the low end -correct??
Are there any tips anyone can give me as far as the time/tankfuls expected before the process is complete? I'm at about 1 gallon of 15% synthetic so far.....
root
